Originally posted by newarts
...I'd assigned it to the "oK" button - so I could use AF for initial focus & finish with manual when possible or needed.
Dave
That's how I tend to use it, too... I try not to hurry the shot, if the subject will let me.
Usually, it's the AF/OK button to get me in range, initially, then 'quick shift' fine tune manually, as needed. I do not depend on AF, or expect AF to be correct every time.
Also, it depends on the lens and setting. Lenses that naturally exhibit greater DOF, like wide angles, offer a greater margin for error in focus, so it's AF (say) 90% of the time. For more normal range lenses, it's AF about 50% of the time. Telephoto's get MF 95% of the time. As to setting.... lots of contrasty stuff around the subject will fool AF, so expect to do a manual fine tune.
Cheers...
