Originally posted by oldshovel80 have any of you ever taken a photo of old photos using a dslr and what kind of quality does it have? i have a bunch of old family photos that i need to copy for other family members. thought i could use my k100d for this , what are your thoughts on this? thanks very much
Have you tried this yourself yet? Try it, you might like it. I've taken a fair number of photos of photos in this fashion, with satisfactory results. Truth be told, the result is sometimes as good or better than the original, in part because I can do some tweaking and cleaning up on the computer.
The suggestions made previously are all excellent advice. A scanner is definitely a better tool for this job than a camera. And if you're going to try it with a camera, there are lots of things you can do to get better results.
But the question we don't know the answer to is, how high are your standards? You might have a choice here between Best Possible Result, and Good Enough Result. If you can get the originals nice and flat, and if you can get good light and at the same time avoid glare, and if you can find a perspective that gives you a properly proportioned photo (in other words, if you can photograph more or less straight on, and from far enough away that the sides of the photo look straight), you may find that you can take photos of old photos that will be good enough for your purposes.
Let me say it again: a scanner is definitely better. But if you don't have a scanner, and you aren't doing this work for the national archive, then don't run out and buy a scanner until you've spent 10 minutes at least taking a crack at it with your camera.
Will
