10-08-2009, 01:05 PM   #1
NASA Moon crash
is anyone planning to take pics of NASA moon crash with telescopic zooms?
NASA says
We expect the debris plumes to be visible through midsized backyard telescopes -- 10 inches and larger
can this be seen thru telescopic zooms?
10-08-2009, 01:12 PM   #2
guidoanselmi's Avatar
I work at NASA JPL and will be at the crash party for LCROSS next morning (impact is est 4:30 AM PDT, Friday)
NASA TV will, I think, be streaming visual from LCROSS itself.
10-08-2009, 01:31 PM   #3
It will take a 10 inch or larger scope to have a chance to see the plumes. Unfortunately it will 7:30am here, and way too bright.
10-08-2009, 01:35 PM   #4
Moderator Emeritus
Same here. I have the lens but 2 problems. It will be too bright and it will be too cloudy.
It seems every time something like this pops up we get rain.....
10-08-2009, 01:40 PM   #5
Blue's Avatar
I have similar problems Peter. On top of that, we have been having 98% humidity at times.
10-08-2009, 02:25 PM   #6
code4code5's Avatar
I don't have a telescope... do you think a 300mm might be able to see something?
10-08-2009, 02:34 PM   #7
QuoteOriginally posted by code4code5 Quote
i don't think so. on the website LCROSS: Amateur Observations , it shows 10 inch telescope has optical focal length of 2032mm.
10-08-2009, 02:43 PM   #8
Actually a 10 inch, F5 scope has a focal length of 1270mm. There are a few guys who have built some 10 inch F6 to F8 range. But they are tough to handle well.
10-08-2009, 04:33 PM   #9
Heh. I'm not encouraged. From sharathk's link, most of the way down the page:
Q: Can I get pics of this event using my digital camera 'piggybacked' on a telescope with tracking?
A: Generally, no. The event would be about the size of a pin head on a kitchen table. You'd need a very large (huge) focal length lens (a lens combination with 3000mm on a 35mm film camera only gets you about 60x magnification. Digital cameras with the smaller chips get you an effective boost of about 1.5 times this for a given lens, but you're still barely getting to 100x mag) to get the needed magnification. Advantage though is you can blow up a good resolution/high pixel digital photo & maybe get a good result with some software manipulation. If you do try, make sure the tracking is good and your scope is used to carrying the camera and large lens weight so the tracking stays on track. Eye-piece or direct projection would be the preferred method when using a normal digital camera. Short focal length 'reflector' lenses, while small and light, are not recommended. Better yet are the digital astro-cameras with a huge lens -- a different web site.
I think I'll sleep in and watch it later on the tee-vee.
10-08-2009, 04:37 PM   #10
Correct, piggy back would not work. The camera would have to be connected to the focuser. And if possible a 2X barlow also.
10-14-2009, 10:28 PM   #11
jhaji's Avatar
Hardly noticable even in this NASA image -
The Associated Press: Moon crash: Public yawns, scientists celebrate
I was wondering whether I could capture it on my 500mm until I realized that the impact would be in broad daylight
camera, crash, moon, nasa, photography
February Moon (feel free to post your moon shots) GLThorne Post Your Photos! 11 05-02-2016 12:00 PM
NASA Astronaut's Photography Manual ChrisPlatt Canon, Nikon, Sony, and Other Camera Brands 3 08-10-2010 11:20 AM
Nikon D3s & Lenses used by NASA link with images Samsungian Canon, Nikon, Sony, and Other Camera Brands 0 07-08-2010 07:31 AM
Nature Moon shots (yop, one more thread on the moon) Martin_Qc Post Your Photos! 3 05-25-2010 10:01 PM
All times are GMT -7. The time now is 09:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
