Originally posted by EddyinGA
...If you do bracket. Why? And, if you don't bracket. Why?
Ed
I do use bracket to deliver a set of PEF files for processing as HDR in PS2 / PS3. This is only used for a scene that exceeds the brightness range of the K10D in RAW mode. The result is a 32bit image that Photoshop can remap as 16 or 8 bit. The result is awe-inspiring (once you have mastered the learning curve!) and can deliver spectaacular results of scenes you would have considered out of range.
I use a 2 stop difference and shoot 3 shots for the average scene and 5 for the extreme high contrast scene. i can shoot with the K10D hand-held in multi multi drive mode and obtain excellent registration. If you use a tripod the conversion is MUCH faster as you can disable the "try to match images" check box.
BTW do you Pentaxists out there find it necessary to disable anti-shake when tripod mounted. I generally forget and yet I have no problems shooting on my tripod.
Ron McDermott
S-E Queensland (Australia)
