Originally posted by Jerry Thirsty If it were zoom creep the second set of arcs would still be concentric with the first
Not true. If the center of rotation (Polaris) isn't in the center of the frame, it will move to a different part of the frame when the zoom changes, or maybe even out of the frame entirely. If it's near the top when zoomed out, it could disappear from the frame altogether when zoomed in. And then you'd end up with two sets of trails, each with a different center point. That's pretty much exactly what it looks like is going on in this picture
Notice that three critical points—the center of the frame and the apparent center of rotation of each of the two sets of star trails—lie in a single line. That's just what would happen if you changed the lens focal length without changing the position of the camera. If that change in zoom happens rapidly enough, there would be not connection between stars (the radial ramps you're talking about).
The lack of a double image in the roof just means it only showed up in the wider half of the exposure, and the longer-focal-length portion didn't have the roof in the frame.
So the question is: what woudl have changed the zoom setting of the lens? Sudden, and quick zoom creep seems unlikely. Maybe someone did it accidentally. Polar bear?
If I get bored, I can try to figure out what the angle of view (and thus the focal length) for each of the two apparent zoom settings is. I don't know what that would tell us, but it would be interesting.
