11-23-2009, 06:58 AM   #16
QuoteOriginally posted by LeoTaylor Quote
Clone out the smoke pentaman? Never, I love the patterns left by each preceding firework, slowly drifting away!
Well, we all have our preferences! The problem with smoke as I see it is it might take the focus away from what you are trying to capture. If you are simply documenting the fireworks, I would be fine with it.
Another reason is - the smoke coverage depends on the wind direction and speed. If there is no wind, the smoke kinda hangs in there, but if there is wind, the smoke scatters and can fill your frame.
Again, preferences and the story you are trying to tell.
11-23-2009, 07:43 AM   #17
Lowell Goudge's Avatar
QuoteOriginally posted by pentaman Quote
Look how much smoke was eliminated by simply increasing the black level in the brightness & contrast curve in the photo posted by Leo Taylor
It's easy to deal with as long as it is not too bad
11-23-2009, 01:23 PM   #18
LeoTaylor's Avatar
Lowell:
I was about 1100 feet from the launch zone so had a 1 second delay.
With Fireworks your signal to noise ratio is very high, allowing you to do what you want with the background. I like the "history" of the last few burst as seen in the smoke. I also like the framing of the trees.
12-02-2009, 05:59 AM   #19
Mechan1k's Avatar
I thought it'd be daunting at first when i took my first fireworks series.
I had just started using a DSLR ... and only had my 18-55mm kit lens.
I set mine wide to 18mm ... manually focussed on infinity ... set the ISO at 100. Saet aperture at f/8 (as that's about the sweet spot for the lens anyway) ... and used Bulb mode with a remote shutter release. On a tripod of course.
I was actually pretty happy with my efforts ... I did leave NR on though ... and has the agonising wait for the frame to finish .. but the fireworks went or about 15-20 minutes anyway ... it was a hell of a long set.
I could have done it better I guess ... but for a first go ... I was happy.
Here's a few:
camera, firework, photography, pictures
When Connected to USB taking pictures cbaytan Pentax DSLR Discussion 2 09-25-2010 02:43 PM
K200d taking pictures by itself kent Troubleshooting and Beginner Help 9 10-01-2009 07:38 PM
Taking pictures of the sunrise... Javaslinger Troubleshooting and Beginner Help 8 02-15-2009 06:18 PM
finally back to taking pictures again... khardur Post Your Photos! 13 10-27-2008 05:14 AM
K100d- Not Taking Pictures spanky12 Pentax DSLR Discussion 4 01-29-2008 07:28 AM
All times are GMT -7. The time now is 09:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
