Update for y'all
The aim of this whole exercise was to find a way to set my camera to take gapless pictures at a time of my choosing in the middle of the night, so that I could blend them together to make seamless star trails.
I already have a cheap and cheerful 3rd party infra-red remote control unit, and by setting the camera onto "Drive Mode Remote Continuous Shooting", custom menu 18 to 2 (slow shutter speed NR - off) and using a manual exposure of 30 seconds I can set the thing up, click the remote once and it'll keep shooting _without gaps_ endless 30 second exposures. Then I come back in an hr, click the IR again to stop the sequence.
Whilst this is fine for what it is, clearly it means I can't just go asleep and set the camera to do its thing when I want it to.
I went out and bought a
Seculine twin1 ISR model iC - which works for Canon, Pentax & Samsung. You can see a pic of it at
B&H - in the UK it cost me £50 or so.
[Note to B&H rep - you've currently have a booboo there. Your description describes it as "ISR (Infrared Shutter Release)", in fact it is not infrared at all
. I have that exact model and it is a "ISR (Interval Shutter Release)" - I think you just got the acronym wrong. This does matter because I don't think there's an infra-red remote timer available for Pentax at all, sadly.]
Anyhow, so fiddling around with this thing means you can delay anything by any time interval and have intervals etc etc etc. BUT! Beware it's cabled. So you must remember not to use "remote continuous shooting" but instead use just plain old continuous shooting (Hi, Lo works fine too). I discovered this after a lot of trial and error so I hope that this saves someone else the hassle. For me it's working on:
M+30sec exposure. Gadget has 4 settings, delay, interval, number & duration: for me this works: any delay I want up to 99 hrs, 1 sec interval, 1 shot, 2 minutes duration. What happens when I use this is that the delay I program in is counted down and the thing starts its 1 shot (for 2 minutes duration). But what also happens,
because I've set continuous as the camera's 1 shot, is the camera just keeps taking until the duration (2 minutes) is fully used up. So actually it gives me 4 30 second exposures with no DFS delay in there, they're taken one after the other.
It is a bit of a bodge job though - that last "duration" setting is supposed to be for bulb exposures which in fact it works for too. So yes I can set up the thing to start taking a B exposure for 2 hrs at 3 am if I want, which is nice. The fact that it's made the M setting work like this is also nice, the result I wanted. So I hope that helps someone in the same boat as me. The next mystery to figure out is why the K-7's 30 second setting actually seems to last for 32 real seconds, but that might be a story for another day.
