First off, I finally got my VIV105 replacement in today and man I almost want to take tomorrow off just to walk around a shoot everything that I see, but that will wait until I get my K10D back from Pentax.
Preface: Picture quality was not my
focus here, pun intended.
First here is the setup, took a lot of eBaying and googling to find these:
Now here are the results:
My models for tonight:
The results from the little Buddha statue were just so rediculous that you cant even make anything out so I will only post the phone pics.
Here is a standard shot using the VIV105 as close as you can get it.
Now here is the same shot with the VIV Tubes on it. These tubes are special cuz they will carry the aperature setting from the camera to the lens so you can shoot in A mode if you have an aperature ring. Not much of an issue here but still a cool feature.
Now here is the setup with the VIV105 with the 2x teleconvertor on that supports Macro while still having the extension tubes connected to the body. This setup did not support the A feature on the lens so I had to manually drop it down to f2.4
Personally I think the results are phenominal, a 210mm Macro, I can get withing 6 inches of the object. Lighting is an issue, but a ring flash is an easy and cheap cure for that [VIV6000 for $70] But I shot these w/o a flash, only my bedroom lights. I cant wait for this weekend to do some real field testing.
So whatcha think?
