Originally posted by attack11 actually, instead of leaving it up to interpertation i offer you these 2 images.
iso100, f8.0, da* 16-50, my bathroom: back to back within seconds so ambient light shouldn't matter.
why are the histrograms, and exposures so different if you can bounce pttl. there's clipping, so it's not the room shape.
90d
45d
if pttl worked with a bounce, then i should a) not be clipping and b) have a properly exposed frame taking into account the light source is in frame.
I think what happened in that test is the flash was firing at 1/1 power to TRY and expose for f/8 ISO100, but 1/1 was not powerful enough. Bouncing eats up a lot of light. Try the test again but with ISO400, f/2.8.
Many folks have said you're wrong, so I'll be one more voice saying "you're wrong"
Canon's E-TTL, Nikon's iTTL, and Pentax's P-TTL all pretty much work the same way. And they all work when the flash is bounced. I probably shoot more than 10,000 E-TTL'd shots a year, and when I shot Pentax it worked about the same.
x-TTL WORKS WHEN BOUNCING!
The only part where the manual is wrong is in stating you need an autofocus lens. You need a lens which transmits the aperture to the body, so an A lens would work as well.
Here's how the x-TTL systems work -
1)Flash sends a brief pre-flash at a known power level (pretty low power)
2)Light goes wherever it's going to go for the shot, be it direct, or bounced on the wall BEHIND you
3)Metering sensor in the body reads the light reflecting BACK from the subject
4)Since the body knows the f-stop of the lens, and the ISO, it can calculate WHAT power to fire the main flash for proper exposure. The metering sensor doesn't CARE ONE BIT how the light "arrives" at the subject, it just sees the light reflecting back to the sensor.
