Originally posted by icywarm But what would we have to expect if we did it?
Well, you'd grow hair on the palm of
both hands and go blinder than a bat. Then it'd suck the socks right off your feet.
Seriously, in a C-172 it'd be about like opening the window in your car at 30 MPH . No big t'ing a'tall.
Pull the window hinge pin and lift it all the way up to the bottom of the wing and tie it to the door latch if you want. Heck, pull the pins on the door hinges and remove that too. It'd get a little windy then if you were to side slip into the open window but nothin' terrible'd happen. Jumpers and photographers do it all the time. Both are within the certified limits of that aircraft.
You can actually control a l'il Cessna by opening or closing either or both doors (plus the throttle if the engine's makin' noise).
Check this video:
http://www.youtube.com/watch?v=oP_CPOH0EbE
H2
