Originally posted by StarDust What you mean to say or what's really happening is that there is only a single exposure, but during the exposure time you have two moments of different luminances.
I think it is basically semantics. We are probably trying to describe the same thing but in a different way. For me, it is easier to "think" of it as a double exposures. When I think that way, then it becomes clear why one needs to control both exposures, flash exposure and ambient exposure, when you are shooting in manual mode (camera and flash).
Strictly speaking, if you define a double exposures as a combined exposures with the shutter opening and closing twice, then I guess it is not a "double exposure".
Please see this.
Four Flash Photography Basics we must know Originally posted by StarDust Now what frustrates me is that the camera has no override for sync speed since the flash fires at a fraction of a second, firing at 1/4 power and at 1/250 s might just be enough to light up the scene, but I guess it has to do with that only a slit is sliding over the sensor at speeds faster than 1/180 s and in that case it would only light up a part of the frame.
I just had an epiphany, I think. The reason that the flash has to fire several times has to do with the fact that it lights up several parts of the frame to make the whole frame lit up.
Is this correct? In that case I'll just have to wait till Pentax shortens the X-Sync speed on their cameras.
With HSS, the flash actually flashes thousands of times a second. For all intend and purpose, one should think of the "HSS flash" as a continuous stream of light that lasts for the duration of the shutter speed.
See this link.
Flash Photography 101, Chapter 4 - Guide Numbers and High Speed Sync - Canon Digital Photography Forums
I am looking forward to the day when DSLR makers can get rid of the mechanical shutter and replace it with an electronic one. When that happens, the x-sync speed will only be limited by the flash duration. Rumor is circulating that Panasonic is going to offer this with their new micro-four thirds camera soon. Apparently it is easier to implement an electronic shutter without compromising IQ on a smaller sensor.
Panasonic GH2 to be first shutter-less camera - Blogs - EOSHD.com
And all Point and Shoot cameras already use electronic shutters. P&S cameras like the G11 are great if you want very high x-sync speed. G11 has 1/2000 sec x-sync speed.
