02-01-2010, 06:17 PM   #1
jms698's Avatar
how to create a moon-light style lighting effect indoors?
I'm trying to create a moody moon-light style lighting effect in an indoor shoot (darkened room).
I want to make it look like a moon-light night, but at the same time also want to show clear details in all the people in the room. Definitely not silhouette. I also want enough light to be able to use a reasonably fast shutter speed - something like 1/30 - without pushing the ISO beyond 1100.
I'm imagining something like movie "night" lighting that simulates night without sacrificing detail and providing enough light for the cameras to record the action.
Can anyone suggest a way to achieve such a lighting effect? Are there cheap ways to achieve it, without requiring a full studio setup?
Thanks for any information and/or example shots.
02-01-2010, 07:34 PM   #2
Damn Brit
Guest
What about a powerful LED flashlight?
02-01-2010, 08:40 PM   #3
jms698's Avatar
QuoteOriginally posted by Damn Brit Quote
Good idea! I hadn't thought of that.
Is there any white balance tweaking or other post-production that you can recommend?
02-01-2010, 08:46 PM   #4
Damn Brit
Guest
I've never tried it. I think a lot will depend on how dark the rest of the frame is and what colour is there. Shoot RAW and you shouldn't have to worry about WB anyway
02-02-2010, 02:57 AM   #5
Using one point light and underexposing should get you there.
02-02-2010, 07:52 AM   #6
noblepa's Avatar
You might want to keep the color saturation very low, almost B & W. In very low light situations, the human eye is not very sensitive to color. At night, our vision is almost B & W, so if the colors are too vivid in your image, even if the exposure is dark, it won't look natural.
02-02-2010, 08:42 AM   #7
GerryL's Avatar
What they do in the movies is use an HMI outside the window and use a blue filter over it.
Don't you notice how in TV or movies that when it it supposed to be night, the lighting is always blueish?
02-02-2010, 09:32 AM   #8
Urmas R.'s Avatar
Exactly, check the color of your LED before. They are often too warm, in which case a gel filter might be handy.
02-02-2010, 09:42 AM   #9
QuoteOriginally posted by noblepa Quote
QuoteOriginally posted by GerryL Quote
Putting these two posts together:
The reason the bluish cast makes intuitive sense, even if it's not backed up by reality (moonlight is demonstrably not blue) is that the human eye doesn't lose sensitivity to all colors equally as the light dims. Reds tend to be the first to go. This is known as the Purkinje effect. So moonlight is within a brightness range which is covered by the mesopic vision regime, where the eye is still sensitive to blues and greens but not so much reds. This leads to a perception of moonlit scenes as having a bluish cast, and explains why Hollywood can take advantage of that effect.
So, keeping the saturation low and reducing what little color remains to a slight bluish hue can help reflect the way the eye interprets moonlit scenes.
It's also important to get your light source as close to a distant point source as possible. If you're too close, or the emitting area too large, you'll end up with soft lighting and/or divergent rays. But the moon is the same size as the sun in the sky, so creates the same kind of hard shadows and parallel rays. I wouldn't hesitate to approximate this by an off-camera flash set for reduced exposure, placed high and as far away as practical.
02-02-2010, 12:01 PM   #10
MRRiley's Avatar
A simple photo flood lamp with a bright CFL and a blue sheet of acetate should work...
02-02-2010, 01:50 PM   #11
jms698's Avatar
Wow, thanks for all the good advice so far.
QuoteOriginally posted by aerodave Quote
So, for example, I might use a Pentax AF360 flash (gelled to blue) off camera and as far away from the scene as possible. Maybe also zooming the flash to maximum focal length (as opposed to wide-angle mode)?
02-02-2010, 01:52 PM   #12
Damn Brit
Guest
QuoteOriginally posted by jms698 Quote
I think most people would equate a moon lit effect as a directional white light. That would be hard to achieve with a flash.
02-02-2010, 03:27 PM   #13
jms698's Avatar
Can you please explain? How is light from a flash different from a flood lamp or LED flashlight?
02-02-2010, 03:38 PM   #14
A flash can be pretty directional if it's sufficiently far away. As for zooming, I don't think it matters much, because the rays that fall on your target will be coming in at the same angles anyway. Zooming in does the have possibly desirable side effect of minimizing stray light to the sides that may bounce around and soften the shadows.
I'm not sure you need to gel the flash to blue. Unless you've got a *very* mild blue gel. But the correction would be so slight that you're probably better off with a slight white balance shift after partial desaturation. The blue gels I have, for instance, would make far too strong a color cast. Moonlight isn't blue...it's just "cool".
02-02-2010, 03:59 PM   #15
Damn Brit
Guest
Fire your flash in a dark room and see how much of it is lit up. Then use a flashlight in the same room, I expect the illuminated area will be narrower and more defined.
camera, effect, light, night, photography, style
Any software with something like DxO's lighting effect? causey Digital Processing, Software, and Printing 1 05-22-2010 09:25 PM
lighting (indoors) Green_Manelishi Troubleshooting and Beginner Help 10 11-24-2009 07:41 AM
How to setup light for these effect? quaker Photographic Technique 11 11-12-2009 03:37 PM
cool multi-flash lighting effect little laker Post Your Photos! 0 07-02-2008 10:27 AM
Lens help for low light indoors!!?? craig1024 Pentax SLR Lens Discussion 6 04-10-2008 12:36 AM
All times are GMT -7. The time now is 09:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
