I shot U7 Soccer last year. This year it will be U8s. I try to shot all players in both sides of the match & both presentations - which can have me running as they often occur simultaneously.
K20D & DA 55-300/F4-5.8 for field shots & DA 16-45 for presentation shots. I use a tripod and it makes tracking & levelling a bit easier.
Try to get the sun behind you - I often can't, and backlighting makes things more difficult. I only shoot daytime. Night time (for a demonstration match I watched) was hopeless. Unless the lighting is very good.
I use AF.C and TAv mode. I have ISO roaming between 100-1600 (typ. 280-560), aperture set at either F6.7, F8 (perf.) or F9.5 for some DOF, and shutter speed set at either 1/500s, 1/750s or 1/000s to reduce motion blurring.
Some of the shots are in my
gallery
All the shots are
here
Here's an ISO analysis from an early match:
Setting 1: 1/1000s, F8
Count: 136 shots
ISO 280: 90 shots
ISO 400: 32 shots
ISO 560: 10 shots
ISO 800: 1 shot
ISO 1100: 3 shots (sideline throw-ins with dark backgrounds - due to either the player's face being obscured or the shot being too static, none of these shots were kept)
Setting 2: 1/750s, F9.5
Count: 59 shots
ISO 280: 45 shots
ISO 400: 11 shots
ISO 560: 3 shots
Using my LV calculator (
http://users.on.net/~dosdan/LV%20Calculator.xls) you can work out the Light Value (light level) for these exposures. For example:
1/1000s, F8, ISO280 = LV 14.5
1/750s, F9.5, ISO280 = LV 14.6 (should be the same, but rounding errors).
The K-x does not have TAv mode, so I'd suggest Tv.
I don't use burst. Just track the action. Experience will tell you when things are getting interesting. You don't really have time to check your shots. I'm often amazed at the things that appear on the shot that I was far too busy to notice at the time. One big benefit of shooting this stuff is it makes me appreciate the efforts of the players on both sides a lot more than I would as a mere spectator.
There's two elements I'm interested in: action & drama. It doesn't bother me that much if I miss a goal shot. I'm not there to document the game. I'm there to spotlight the kid's efforts.
Dan.
