Sounds like you'll have fun at least!
Your best beach shots can be in the
middle of the day, when the water will look as clear and blue as it is going to get.
+ 1-2EV for sure, and keep the polariser on, knowing that it darkens the sky that is about 90 degrees to the sun the most.
If you're into people shots, but not inclined to use a fill flash, you can get great results under partial shade (think beach umbrella).
I agree totally with those warning about sand and salt. I slide my entire kit into a roll-top dry bag, before jumping on and off small boats, and never change lenses outdoors unless it's dead calm. Get the lens that you want onto the camera before you leave your room/car, and leave the rest of your kit safe and dry. In addition to desecants, keep your room aircon on, and a degree or 2 cooler than normal, with the fan speed low - not great for the environment, but your camera will thank you for the low humidity.
If you like low-light beachscapes, go to the ends of the beach, where there will be rocks and other "interesting" subjects. All of the usual rules apply: tripod, timer, ND filters, low, close, small aperture. Rinse your tripod with fresh water ASAP.
Have a great trip.
