Originally posted by alehel We've reached an interesting point in camera development when ISO 12800 doesn't produce enough noise
Over here
Manual Focus Lenses :: View topic - Monochrome sensor; very interesting outlook we're discussing a proposed B&W sensor. A Bayer-filtered sensor, with its 1R+1B+2G blended elements, throws away 1/2-3/4 of the received light. Remove the Bayer filter and the sensor is 2x-4x more sensitive, and has 4x the resolution, and lower noise. With everything else the same (lens, display size, etc) the mono sensor has around 10x-20x better performance.
To get the ISO 12800 noise level on a mono sensor, you'd have to shoot at ISO 128k at least, more likely ISO 256k. If you want more noise, bump it up to ISO 512k. At the other end, you'd have a base of ISO 400, virtually grainless. And that's with existing technology. Take the Kx's sensor. Strip off the Bayer filter. Resolution is now around 50mpx. What'll it take to get enough noise for that Tri-X @ 6400 look?
