Originally posted by stewart_photo I'm not sure the highly specialized Tiffen filters are best for this application. For example, the Soft F/X, Warm Soft F/X, and Sofnet Skintone filters are primarily designed for people (portraits, etc), not guitars. The Black Pro-Mist filter is a step in the right direction, but I personally wouldn't use it for this. In fact, I probably wouldn't use any Tiffen filter, or any distortion filter at all, for this subject. But, if I absolutely had to use a filter, a very mild blur filter, or even the camera's built-in digital filter at it's lowest setting, would likely be the better choice.
stewart
I hear what you're saying about the Black Pro-Mist, Stewart.
I've used it for female portraits, but didn't like it nearly as much as the warm Soft F/X.
The Soft F/X filters are my favorites, because they don't lower the contrast as much as the other filters do. By the way, the Soft F/X filters are only available in grades 4 and 5 as a special order from Tiffen, as per an e-mail response I got from someone there over a year ago. I bought my grade 5 filter a while back.
I think the Cokin Pastel and the Black Pro-Mist give similar results.
Obviously there's no one filter that's right for all soft shots.
I'll have to do some more testing, and this time see if I can round up some good-looking ladies as the subjects.
Mike
