The inspiration for the final design struck me while I was playing with my first tripod modification. When trying to get the next level, I was adding bluetak to the back and the front of the mount - at the back to push the camera forward, and at the front to increase the elevation of the front of the camera. It got me to thinking that this problem could easily be solved with a 'ski jump' mount - one with a slight curve so that the nodal point would automatically stay in the correct position when moving the camera forward or back...
I had also seen the rather groovy looking circular flash mounts made by 'really right stuff'. So my mind was now set - I was going to use a circular 'ring' mount...
The key benefit of the curved track mount is that once the nodal point is at the center of curvature of the track, no movement of the mount will move it from that point in space. And with some careful thinking, all that is necessary to get the nodal point to the center of the circle is a single adjustable track, and a hinge for the track to rotate on.
So I had reduced the design to a single hinge point and an adjustable rail. Also, the joint of the rail to the track could be a right angle - good for stability.
So its onto the build!
