Originally posted by leadbelly Hmmm... thanks for all the replies. Are the Vivitar and Sunpak flashes okay? Also, what do you mean when you say "I need a flash that rotates 2 ways?" as aabram points out... I'll probably go with the 285HV or the Sunpak... but if the difference in price is not that high, maybe a Pentax, I wouldn't want my camera to get fried...
The NEW Vivitar 285HVs are designed to be digital-safe, even with the (relatively weak) Canon DSLRs. Beware of older used 285s and I think even some older 285HVs.
The only things that a Pentax flash gains over the 285HV currently are:
Built in wireless triggering (Can add RF wireless triggering for $30)
High speed sync (for balancing flash against daylight with high shutter speeds for special "super flash fill" tricks)
P-TTL (performs worse than metering with an on-flash sensor except in niche situations such as macro photography)
Not worth the fact that the 540 is approximately four times the price of the 285HV. Not returning my 540 to B&H before it was too late to return was the biggest mistake I've made this year. I own a 540 and am incredibly unhappy with it.
That said, I've seen in another thread that firmware 1.30 for the K10D appears to be changing exposure behavior despite the fact that the firmware summary makes no mention of anything other than SDM support. After reading that I'll be trying 1.30 this weekend to see if it improves the situation of the AF540 on a K10D.
For more on the 285HV, browse around strobist.blogspot.com - lots of tips on using it, and it's the core of MPEX's new "Strobist Kits". I'm probably going to be buying one in addition to my AF540 in the next month, and also likely selling my 540 in the next 3-4 months.
