Originally posted by garyk I am going to buy a flash for my k-7. But i only use it for bird photography. Can the 500 work with the k-7 at all.
And what does P-TTL mean.
As noted you can use the flash and the camera will fire it but you'll be adjusting output each time your situation changes. If you are continually (in one sitting) shooting the same type subject, distance, etc that won't be much of a problem. Once you change your setting though, you'll be recalculating the flash output.
Very Simply put, P-TTL is Pentax's proprietary TTL. Each manufacturer has their own (I think Canon is E-TTL).
Originally posted by jogiba I have the DS2 and AF500FTZ flash with TR Power Pack II and the DS2 was the last Pentax DSLR with TTL flash mode and the only one with 2.5" LCD and pentaprism finder. I also have the AF400T with Quantum Instruments battery pack.
Per the database, the DS2 will work with both TTL and P-TTL. The K7 is P-TTL only but you knew that already, right?
