Originally posted by trishytee A friends three year old climbed my ladder, the sun behind her looked nice on her hair so I shot this using the flash 1/100 f16. What could I have done to avoid the lower part of the sky going white.
Thanks.
Oh, using a borrowed computer at present and have only elements 7. What can I do to open RAW files as there is no Bridge with elements?
Thanks
Hi trishytee, I believe this is where your AE-L button will come in handy. Meter the sky behind your subject and press AE-L ( now the camera will expose the sky correctly) recompose and shoot with flash ( flash will take care of the subject exposure ) as in your original shot. As your subject is quite large in the frame you may find you need to change to "spot metering" to get a more accurate measure of the sky. You may lose the highlights in the hair with less exposure of the sky, so you will need to readjust to a slightly less bright part of the sky before you lock exposure with the AE-L. Much easier to do than to explain! Hope this helps, have fun.
