Originally posted by fsge Your calculation must be wrong.Odd is around 1% per drawing so 1% total as it is linear operation.
It's not wrong, I just forgot to multiply with 100 as UncleVanya said. Also this is assuming you somehow get a raffle in each one of the three giveaways.
This is basically a series of repeated independent events, so this is why the odds are a bit more than 1% (assuming you participate in all of them).
To calculate odds for something like this, you use the NO trick.
First draft there were 128 entries, so your chances of winning were 1/128. Your chances of NOT winning were 1-1/128 (so something around 0.992).
For the second draft there will be 300 entries, your chances of NOT winning would be 1-1/300. Same goes for the last draft.
To find out what is the probability of NOT winning any of those consecutive drawings, you just multiply the probabilities. Then you subtract the result from 1 and you get number that represents the probability of the opposite of not winning 3 times in a row, which is actually winning one of the drafts.
Just to make this clear, I think this giveaway is a terrific thing. I was not complaining in any way about the odds being low in my original post. I just thought it would be funny to know exactly what are the odds to win a K-1 in those 3 months ( that's IF you get in the raffle).
If the number of consecutive giveaways increases, your chances may increase significantly. For instance if there were 100 giveaways with the same mechanics and you take part in all of them, your chances of winning one are around 60%. Think about this way. You have a bag with 99 black balls and one white. If you get one out with your eyes closed, look at it and put it back chances to get the white one are slim. But if you repeat this a lot of times you will eventually get the white one.
