Originally posted by Adam If you want entirely uncompressed photos, please use the user photo gallery.
The attachment system only attempts to compress if the filesize or dimensions exceed the maximum limit; otherwise no compression is made and quality is preserved.
For web viewing purposes, I recommend an 11-quality, 900-pixel jpeg. That should look perfect on the forum
Regarding the image itself- great capture of the duck's expression, but I feel like there is too much negative space. Also, you typically want to avoid shooting pairs (although it would seem appropriate in this case).
Adam,
I though that "resizing" the image at 1000 pixels at the widest side, then saving as "save for Web and devices" (in Photoshop) would be ideal to attach, but that seems to be degrading the quality of the picture.
You suggest using the "user photo gallery" ... would that be the same process (file-size-wise) as using the photos in the "Albums"?
So, if I am going to just upload the 2.52 Mb file instead (as I mentioned to Lee above) that should be better ... let me go try that now.
Thanks for the critique.
Indeed, a bit much empty space in front of the birds. I like keeping that sort of space to give an idea that the birds are moving right to left, though perhaps here there was too much.
I have lots of photos of birds "single" ... why then is it not "typical" to have a pair (couple) ?
Thanks for the reply!
JP
