I would suggest a different type of improvement for your image. Neither of these renderings work with the inherent limitations and strengths of the shot.
There are few basic issues here. The first is the color. This type of yellow is quite challenging for most DSLR sensors to reproduce artfully. In addition, the lighting is on the flat side, especially as the eye heads toward the center of the image from the left side of the frame.
Thirdly because a fairly shallow DOF was used, the petals toward the outside of the flower are more out of focus. Sometimes that's quite OK, but in this instance the ones that are (at 7 o'clock and 10 o'clock especially) distract from the strengths of the shot, which highlights the form of the flower. With more contrasted lighting the water drops could have been leveraged more strongly, but that's not to be.
So to go softer overall, transform the color to something more impactful, and still convey the glory of the flower, I'd suggest you try a more high key rendering. The softer parts blend together better into a more impressionistic whole.
If you don't mind, I grabbed your image and have this as an example. In Lightroom one can easily change the amount of vignetting as well as color balances.
Hope this helps trigger more ideas.
M
