Originally posted by Ash Two simple ways of making the intended subject bigger in the frame are to get closer (with your feet) and/or to zoom in (with the lens). The first of these is important, if possible, then zooming is used only to get the perspective required.
To elaborate a bit on this:
If you can go nearer to the statue, you could use a shorter focal length, but still have the statue big in the picture frame. The closer you are to the subject, the moreemphasize is put on the statue and evyrthing in a distance will appear much smaller in comparisson. This is sometimes referred to be the "wide-angle perspective".
Ofcourse this name is misleading. Perspective has nothing at all to do with the lens you used, because it is a result of the distance between you and your subject.
So, if you use a tele lens and photograph the image from a distance, you will not change the relative size ratios between the statue and other things in your image (the columns for instance), but still you could make a shot wich frames the statue more tightly as you did.
If you stay at a fixed position and then use a tele zoom lens to tighten the frame, you will NOT change the perspective - you just change the angle of view.
If you get nearer to the subject and you WILL change the perspective.
Ben
