Originally posted by KerrTexas To address my own question regarding the 1200; Based on reading your post, Clark... They are not referring to resolution but dimension...thus a 2000 x 3000 pixel image would exceed the 1200 image "size" requirements.
sorry, I haven't had much of a chance to reply to your PM yet
but yes I would assume they were talking about image size
so even though your image exceeds the 'size' requirements, it was presumably rejected because of it's lack of sharpness
so next time make sure to get that shutter speed as high as it can get, and don't forget it's better to underexposure and get a sharp picture, than to exposure correctly but get blur- you can correct about 1 stop in post production, so if you've set your iso to 800 (and I recommend you don't go above that on your DL) and your apperture to the lowest, but the shutter speed is still too slow then hold down the +/- AV button and use the scroll wheel to add -1 exposure, this will force the shutter speed up but obviously will underexpose the image
