Originally posted by Adam I think the shot is a bit soft, but, apart from that, I really like it! You've got a great composition going, and the colors and exposure are spot-on! How'd you capture this from such an angle?
I was standing on a bridge. I cropped a bit to eliminate any sign that this isn't plain ocean
You're right on the softness. It's 1/60s only which is too slow. However, in this shot I was lucky that her head stayed relatively sharp. So, the motion blur now helps to visualize the action. Nevertheless, I made a bad choice on exposure time.
Originally posted by Class A I'd try to make the water bluer; its current colour is a bit "blah".
Good suggestion!
I found it hard to turn the greenish color blue. And the water IS green, coming from the mountains ... So, I left the greenish cast but tried to remove the color cast from shadows in the water and made the water look "fresher" overall.
BTW, the shadow is from trees overcasting the scenery. There won't be many surf shots with this kind of sunny spots pattern
