a few shots from this past summer's harvest for your amusement. All comments requested / appreciated.
This first one is the one I enjoy the most. Photographed under a covered patio with natural daylight and a polarizer to cut the glare on the surface of the tomato. There still seems to be more glare than I would like.
K10D DA*16-50 @ 50mm ISO100 f16 for 1 second
This next one I like conceptually but didn't quite work the way I wanted, yes there is a bit too much clutter behind the tomatoes, sure I should have used the polorizer to cut the glare on the tomatos but what I had most trouble with was whether or not I was getting enough depth of field. If I focused on the flag the tomatoes were way out of focus. If I stopped the lens down further then the light breeze started to blur things.
K10D DA16-45 @16mm ISO 200 f8 1/125 second
This last one is nothing special photographically, I'm just showing off my crop. The first round of several harvests. They are a Japanese variety known as the "Momotaro" pink skinned, juicy and very sweet. It takes about 3 quarts of tomatoes to make 1 quart of sauce. I ended up with about 16 quarts of sauce this season (not to mention all the were just eaten on the spot).
K10D DA* 16-50 @31mm ISO 100 f16 1.3 second
I hope you all like these as much as I do. Any comments on how to improve these images will be greatly appreciated and will likely be put to use next season.
Thank You,
Chris A. Kirk
