12-16-2010, 02:36 AM   #1
loule's Avatar
[langtitle=fr]Carré jaune et bleu[/langtitle]
Lens: Pentax DA 35 mm f:2,8 macro Camera: K10D Photo Location: Fos sur Mer ISO: 100 Shutter Speed: 1/200s Aperture: F6.7
Les dernières fleurs de ma jardinière qui résistent au froid.
12-16-2010, 09:26 AM   #2
slowpez's Avatar
Nice colors here loule. Is that ice I'm seeing on the bottom left of the flower near the stem?
12-16-2010, 01:10 PM   #3
Interesting.
Where do the colors come from?
12-16-2010, 01:33 PM   #4
A "Ring Light" that slips over the lens and is circular provides even light and/or flash for close-ups like this. They can be found at various prices on the net. Otherwise a simple white piece of stiff paper board can be held or mounted on a tripod or stick to either put the whole flower in shadow or light. That will avoid the flare on the right tips of the petals and lighten the center. Appears you have used "average" metering.
12-16-2010, 06:52 PM   #5
BigDave's Avatar
So close! The colors are great, but the out of focus petals blocking the center of the flower (the anther and stigma of the flower) are a distraction. The exposure is right on. It would have been real easy to blow out the highlights on the back petals.
12-16-2010, 11:37 PM   #6
Ash
Community Manager
Ash's Avatar
Pretty decent result and as mentioned focus could have been improved with more DoF and highlights better controlled. The colours do look manipulated, but with less obvious alterations this shot may be quite attractive.
12-17-2010, 01:12 AM   #7
loule's Avatar
Merci messieurs, je fais de la photo depuis deux ans et j'apprends tous les jours grace à vos conseils, dommage que les traductions sont quelquefois difficiles à comprendre...
Pour la couleur du fond c'est du post traitement à partir d'un prélèvement de couleur sur une zone bleue
bleu, critique, jaune, photography
Landscape Le pont bleu à Martigues loule Photo Critique 6 12-20-2010 01:30 AM
netteté sur Pentax K-x Rom-aie Pentax DSLR Discussion 4 11-26-2010 04:54 PM
Bonjour de Québec! blueryder Welcomes and Introductions 2 11-26-2010 04:52 PM
Nature Une plage encombrée loule Photo Critique 3 10-05-2010 12:59 PM
Problème avec K-X et molette de sélection Tapirashabrack Pentax DSLR Discussion 3 09-19-2010 12:54 AM
All times are GMT -7. The time now is 07:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
