Originally posted by Fixcinater I'd suggest finding a way to diffuse the light sources you are using. They are casting hard-edged shadows which aren't too flattering to women's faces unless you are very specific in how you use them. They also give odd-looking pin-point catchlights in subject eyes.
Try setting up a big reflector, using the spill from your main to bounce off reflector for some fill, and then using your 2nd light on the background. No light on the background is killing these shots, IMO.
Thanks, I know I need a lot of improvement, and may or may not "get there" in time. It was recommended to use a large sheet of white foam board as a reflector, but I haven't been able to try it yet. I am anxious to see what results I can get with it.
The background....when I go light, I get complaints, when I go dark I get complaints, which leads me to believe this may be a "personal choice" issue? I like the dark best, except for the times I like the light best........
Best Regards & Thanks again!
Rupert
