With wide aperture lenses, keep in mind that the widest aperture will probably NOT be the aperture that will give the sharpest image, even at the point of focus. The general rule of thumb, the lens is sharpest 2 to 3 stops down from the widest aperture. So for a f1.8 lens, f3.5 to 4 will be about right. But with an f1.8 lens, the lens will have a range of a couple of full f stops that will give the sharpest images before diffraction starts (at about f11 or 16 and beyond), where sharpness starts to be negatively effected again. So you can play with the best aperture to give you the DoF you are shooting for and still get a REAL sharp image.
And the points about having NO DoF to work with is important. You are shooting moving objects and want them in focus? Luck will be as important as your equipment!
Reason: typos
