Originally posted by Ash What attracted you to take a photo of this scene?
To me, it would be the textures and colours - and for those reasons, you would want to bring these elements out as much as possible in your image, capturing it and processing it with this in mind.
Stuck on a car ferry in Lake Michigan, I took pictures of
everything. The above shot was from the lower right of this:
It was an overcast evening, the light was a little flat. I did a little work with curves, but I'm not one to embellish much - what you see is what it was.
I attribute the corners being a bit soft to the shape of the drum pulling them out of focus. I played with a few different compositions but this proportion of blue and brown made sense in my head.
In hindsight, shooting at an angle rather than straight on would have brought more texture to it, but also limited depth of field given the available light I was working with. I kept the sharpening to a minimum, it looks better to my eye at a
much higher resolution.
Thank you all for the comments. This is one of those where being there, it means more to me than it does out of context. I need to find a way to add context to these somewhat abstract compositions.
