Originally posted by jolepp ...looking for CC / improvement tips.
Hi jolepp. Just some (rather subjective) notes.
Composition is OK but I think you could give it more space in the right bottom corner; your nephew (?) is a bit tight on the frame.
In my monitor (I don't care that much with calibration worries) red tones seems a bit overly saturated; a more muted color tone should improve the overall look of the image (but that's because I like it, particularly in portraits).
You may also consider a B&W conversion, as they go particularly well in portraits (for me, again). Furthermore, the photo may need some (color) noise reduction work; conversion to B&W may fix that, if you don't succeed by other means.
Finally, you could do some retouching, softening some blemishes, removing some background distractions (this may imply some hard work: removing that dark line behind your sister's head might be a tricky job to do, but you could try softening it a bit), and balancing tones also in the background, namely reduce the luminosity of the left-top corner to match the right side of the background.
Hope it helps.
Cheers.
Reason: typo
