05-31-2011, 06:52 PM   #1
Workingdog's Avatar
Strobe help needed
Lens: Pentax 55-300 Photo Location: York, PA ISO: 200 Shutter Speed: 2s Aperture: F27
I've been playing with high speed flash photography for a while and have gotten some good images but the proximity of the flash makes for some harsh lighting. How can I tame it, particularly with somewhat glossy/reflective subjects like this egg, balloon, tomato, etc. Is it just a matter of making a diffuser such as tissue in front of the flash. I would welcome suggestions from some of you strobists.
05-31-2011, 09:15 PM   #2
Ash
Ash's Avatar
Yes, diffusing the light source has an important effect on the way your subject will render.
There are different ways of doing it, softboxes, umbrella or bouncing off nearby walls/ceilings. You can also get dedicated flash diffusers like the Lumisphere or Stofen, but they are harder to control the light source because of light spillage away from the subject area.
06-01-2011, 10:47 AM   #3
philbaum's Avatar
QuoteOriginally posted by Workingdog Quote
One problem with doing high speed is that it usually requires using a small fraction of the flash power. I see some shadows in the image, not very good lighting. I've just started doing strobist things so take that into account.
I would suggest using more than one flash and/or side wall reflective surfaces such as mat board or aluminum foil. If you are doing more of the egg onto a flat surface, might consider light from underneath using plexiglass or real glass.
Good luck!
critique, flash, photography
Strobe/Exposure Difficulties HELP! Ed n Georgia Pentax DSLR Discussion 10 03-23-2011 09:37 PM
strobe light question slip Pentax Camera and Field Accessories 8 01-29-2011 06:06 PM
High Speed Strobe BillM Photographic Technique 3 09-18-2010 03:28 PM
Looking to purchase my first strobe, thoughts noahpurdy Pentax Camera and Field Accessories 20 02-26-2010 04:50 PM
Remote Strobe Setup Help Needed izzyinstl Pentax DSLR Discussion 5 08-03-2007 07:47 PM
All times are GMT -7. The time now is 02:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
