The reason the spider appears to be floating is because I have it on a sheet of thick glass, at those magnifications even the finest papers produce a distracting background so to reduce this effect I chose to elevate the subject above the paper. Main light was with an AF540 in a 40" softbox though In retrospect, I should dodge the highlights in the eyes to reduce the annoying pattern that is visible and I should have had an auxiliary light behind the subject to bring out the texture in the subject.
I didn't bother DOF stacking with this image.
