Originally posted by jerryleejr Just outta the box, no post processing trying to get the low light dialed in (1st pic) and yes I have the threads on that subject just still fiddling with it. Also the AF seems to be locked in to the wrong part of the pic on one of them (last pic).
Hi
First picture. I am not sure why, with all that light around, you chose to take the pic in deep shadow.
If you want to do this you need to roll up for the shoot with a bit of extra gear, the least of which would be fill flash. Your on board flash would have been fine for the start.
So unless you want the challenge for PP work, I see no reason to take the shot the way you did.
A fill flash would have resulted in something like this most likely.
Greetings
