Originally posted by Bruce Clark This was taken on a very dull overcast day. I an trying to increase the cloud contrast by selecting the sky area and adjusting levels in Photoshop Elements. I am left with a distinct line between the rock and sky.Suggestions on how to eliminate this line would be most welcome. I habve tried various levels of feathering the selection to little effect.
Hi
Never seen or have created such pronounced lines as the result of PP. Don't really know how you achieves them. There are of course white and black sharpening halos mainly as a result of aggressive oversharpening, but not to that extend.
If you wish to make drastic changes (as in your case the sky) there is of course, as they say in the classics, more than one way to skin a cat. In your particular case I would have "knocked out" the rock and foreground from the background. For this sort of thing I use "CREL KnockOut2". Your image is particularly easy for this treatment. Once the rock and the sky are separated it is easy to "slide in" another sky (any sky) or work on the current one to your heart's contend and then slide it back in again behind the rock. (Use layer for this)
If you do not want to start over with your existing photo it can be rescued by just cloning out the offending line. Use a 5px size clone stamp and carefully move along the edge of the line, bit fiddly but it works. I use a tablet rather than a rodent which makes the job much easier.
Greetings
