So much advice, thank you so much I really have learned a lot. I took all your responses and will work on them
Here are a few responses back to you all.
Originally posted by smf I find the large circles distracting — also the light areas at lower right. You might want to tone down the bright areas atop the cap.
Yes, I find the lower right lights distracting, thanks for pointing that out.
Originally posted by smf Although the image is good as presented, you might want to also try some cropping from the right or the left, bringing the bee away from the center. Another option might be cropping down from the top, creating a rather shallow image.
Thank you for pointing that out. I am with you, it's a bit drab if it's DEAD CENTER. ha ha Thanks
Originally posted by smf Might there be a bit more of the image at the left? Part of the rear flower is clipped off. And would you consider cloning out the small, dark spot on the foreground petal of the front flower?
These images came straight from my camera. I do have photoshop however I want to stick to %100 natural photography.
Originally posted by top-quark suggest a dedicated macro lens as being better for this sort of subject matter
I think you're on to something. I just might have to get a macro lens. Would you have a recommendation for a particular lens?
Originally posted by top-quark I would certainly lift the shadows in post
Originally posted by top-quark bounced flash
I'm gathering that macro sometimes needs a flash. I have two flashes and considering making a
macro flash Originally posted by FowlerJphotos step down a tad and get everything in focus
Sweet, I think you're right about stepping down to get the whole object in focus. Now that I think about it, I don't really see any products photographed with a shallow DOF. Thank you!
Originally posted by top-quark It looks as though you used flash for no. 1
You are correct actually. Ifg to mention that. Not good that the camera didn't register that in Exif.
Originally posted by top-quark As for your question about low light settings for the DA* 55. Best setting for low light is generally a bit of bounced flash to make your available light problems go away. If that's (socially) unacceptable then use TAv mode and look for a max shutter speed of maybe 1/30 (less if you're trying to photograph fidgety kids). Set aperture to taste and let ISO go, more-or-less, where it wants to; you've got a K-5! Don't always use F1.4 just because you can: one eye in focus and the other not is generally not a good look!
So true, Thanks for your advice!
