Originally posted by baro-nite As to sharpness, those are pretty slow shutter speeds if you're shooting handheld: either bump the ISO to get a faster speed, or use a tripod.
I can't claim any expertise on architectural photography, but this looks like a challenging location for getting wide views, due to all the fences, bushes, and so on. In #2 you've found a fairly wide viewpoint, but by zooming out to 18mm and standing close the foreground becomes overemphasized. And because you're below the house, the converging vertical lines become pretty extreme. Try re-shooting #2 from farther away (and higher, if at all possible) with a longer FL.
#1 is a nice perspective on the house (although it looks a little bit tilted). The bushes in the foreground are distracting, as is the blown-out sky. The blue sky in #2 is really helpful. Looks like you had partial cloud cover; the light on the subject is very soft. Some glare off the roof; maybe try a polarizing filter.
If you get the chance to shoot interiors, I'd say at a minimum you'd want one flash you can bounce off walls or ceilings, and multiple flashes could really help. Again, speaking theoretically rather than from experience.
Yes, you are right about the challenges in the location. I must stress that I was not setup as I would had I expected to be on the grounds. I had no filters nor my tripod. My K-r with 18-55 kit lens on and that's it. I have been lately trying to just practice shooting more, so I bring my camera with me where ever I am. As it is the kit lens, if something happens to it, I am not out a whole lot.
It may very be possible to shoot #2 from further away. I will have to try that if/when I return. As for #1, I am standing outside the property wall which gave the best shot of this portion of the house. I was intentionally trying to frame this shot through the existing greenery.
With the possibility of shooting the interior, I was leaning more on the side of using natural light throughout the home. With these historically large windows, it should suffice with slow shutter speeds on a tripod. I want a natural look, but I will have to look more into this. (PLUS I will be able to suggest time of day and look at that days weather, so this will play in my favor.)
Originally posted by Katier Both the shutter speeds should be fine... 1/28 = 1/30th ( in effect ) and 1/18 is slower than 1/40th that it was shot at. I've shot at that kind of speed with a way longer lens than that with no issues.
The biggest issue is the perspective issues you mention. Second shot definitely needs either shooting with a proper camera :P ( Large format with tilt/shift
) or accept some cropping by holding camera vertical then cropping.
Though I think the shots came out OK, I'd like to see the shutter speed a little bit faster to capture image more sharply.
Yes #2 is somewhat problematic with the perspective. I myself like it because it actually makes the bldg more grand but that might have a connection to my familiarity with the property and it's history.
The challenge is the location where I stand is below the bldg line plus it's a slope down away. If/when I return, I will try some different things to overcome this.
Thanks for the critiques.
