08-23-2012, 07:07 PM   #1
Macro Suggestions
Lens: FA 50 2.8 Macro Camera: K20d Photo Location: Yard ISO: 200 Shutter Speed: 1/60s Aperture: F9.5
Trying out macro with a newly acquired FA50 Macro. Used on board flash. Let me know how I can improve.
PENTAX K20D  Photo
08-23-2012, 07:58 PM   #2
Ari
Ari's Avatar
It's a nice shot. My only suggestion is to forego the flash. Are you using a tripod? I'd be nervous about bumping up the ISO too much (I have never been a big fan of high ISO performance with my k20) but a good support and a relatively inexpensive wireless shutter release (like this one here:Pentax Remote Control F 37377 B&H Photo Video) should give you good results. It will also allow you to open up the aperture a bit and use a shorter shutter speed. Of course, with non-buzzing subjects, you can use a smaller aperture and longer shutter time.
08-25-2012, 11:08 AM   #3
yeah, I would go tripod, shutter release (wither wireless or cable), and ditch the on-board flash if you can go with an off-camera flash. For those moving subjects, it might be hard to lose flash altogether. IF you can't get flash off the camera, try diffusing the don-board flash so you don't get as much of the highlights. It isn't bad...I think I am just feeling that the flash is just a little harsh. Still, pretty good for starting out with macro!
08-25-2012, 12:03 PM   #4
Great capture.I don't attempt to use a tripod for this kind of shot as the subject will be gone before the setup
08-25-2012, 02:03 PM   #5
I like the photo a lot. Some of the specular reflections due to the direct flash might be toned down a bit by putting a Kleenex over the flash to act as a diffuser - or a real diffuser..
08-29-2012, 05:19 AM   #6
Thanks for the compliments and suggestions! I was not using a tripod, as I was always missing opportunities by the time I got the camera positioned and focused when I tried that. This shot was taken at dusk in a shaded area, so the light was not great. I will definitely try the diffuser technique or no flash in the future.
Thanks again,
Bret
08-29-2012, 07:11 AM - 1 Like   #7
baro-nite's Avatar
Tripod and no flash for insect macro is going to test your patience. Your shot looks quite good for on-board flash. At macro working distances, though, you get very noticeable light falloff with most of the light at the top of the frame (because at such a close distance, the pop-up flash is pointing well above the center of the frame, and also possibly because the lens is blocking light from reaching the lower part of the frame). The Interfit diffuser makes for a pretty decent macro diffuser for the on-board flash. It's better than putting something directly over the flash, because the Interfit goes on the front of the lens and hence becomes a very large (relatively speaking) light source for macro subjects.
08-29-2012, 09:49 AM   #8
Good idea,didn't know this product
09-12-2012, 10:09 PM   #9
Nick Siebers's Avatar
With a toilet paper roll, I have cut off one end on a diagonal. Line the roll with aluminum foil, add some white material over the end (Handkerchief would do it). Strap the back onto the pop-up flash and adjust length as needed. Works quite well!
critique, macro, photography
Macro gear suggestions on going beyond 1:1 ratio Phosphene Troubleshooting and Beginner Help 19 02-12-2013 01:52 PM
Cheap Macro Setup Suggestions - Here is what I've got... JenniferLeigh Pentax SLR Lens Discussion 13 02-01-2012 09:11 AM
Macro suggestions photochimp Photographic Technique 14 01-11-2012 03:00 AM
Suggestions on finding the Matched 1:1 Macro Adapter for Cosina 100mm f/3.5 Macro? pentaxk1000denver Pentax SLR Lens Discussion 10 06-18-2011 02:41 PM
Suggestions for macro photography xs400 Photographic Technique 9 05-18-2007 05:20 AM
All times are GMT -7. The time now is 06:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
