Originally posted by baro-nite
The tighter crop and brighter tone curve makes the foreground pop beautifully. I think you may have gone a touch too far toward yellow/green, but that's a question of taste (if you ask me; I don't think the goal is realism per se here). But that is why the sky looks a little washed out now. Do separate color treatments on sky and foreground. I'd leave just a little more space at left, so that rock doesn't get cut off. Don't get discouraged, you're doing great here.
Don't worry, I am not discouraged in by any means! If anything the more I screw it up the more I want it perfect!
Vicious cycle..
It's probably also quite hard to get it exact, although it's calibrated I am still using a TN panel. Which I have been told will make landscapes difficult (reads: impossible) to get colours right. I still should be able to get it closer than I currently am though.
Again I'll have another crack tonight when I get home... I will get this right!
Originally posted by Gregory_51
Hello again
There are always things that can be tweaked and experimented with. I sometimes I will take a photo and run with it in different directions and be torn about which I like better. On some I have 3 or 4 versions that I like of the same image and they have a totally different look an feel. If you are working in lightroom you can do a lot with the adjustment brushes for specific areas. I don't know if you use presets or not but there are lots of them out there to download and try. They can get you in the ballpark quickly and you can tweak it from there. I done an edit (hope that's OK) and posted in on flkr. It gives an idea but the images really fall apart quickly when reworking a low res jpeg. I've brightened and warmed the rocks and cliff and such and added contrast.
2012-11-07_085635b | Flickr - Photo Sharing!
Cheers
Greg
Greg, I like what you have pulled from it, I don't mind at all if you tweak my images! It is easier to show than tell with photo editing.
- I like the deeper blues in the sky, and the more natural yellows orange and reds in the sun.
- Bringing out the details in the cliff really helps add another element to the shot.
- The rocks look significantly better, more what I was originally aiming for. I must have let my self run away with photoshop lol!
I have a heap of presets, I just need to organise them! they are all over the place to be honest and makes it really hard to find anything. Also I will post a higher res file when I make the edits tonight, if anyone else has some adjustments they wish to demonstrate.
On a side note: how do I show a before and after in photoshop like that of the lightroom development?
