Originally posted by CrazyNuts What software/methods did you use
It was much easier than I thought...done in Photoshop CS5.
I used the gradient tool which allows the selection of an area that would remain untouched (and therefore in focus) - in this case it was the section of around the height of the ferris wheel across the whole pic. Then a simple fiddling around of the lens blur (until it just
looks right) applied to the sections above and below the focus point (with more blur being applied the further away from the focused area). Oh...then a bit of a saturation boost, since toys and models are always very colourful, as this is what the tilt-shift effect is supposed to emulate.
Sorry if I'm not explaining it correctly...I got the info from a number of different websites while I was at work, and then just applied whatever I had managed to commit to memory when I got home (by then, the laziness had kicked in again and I was only going to try and find the same websites if I ran into trouble - luckily, I didn't!).
