03-19-2013, 07:13 AM   #1
wullemaha's Avatar
stairs
Lens: SMC Pentax M 50 1:1,7 Camera: Pentax K-30 Photo Location: Tokyo, Hibiya-Park
I took this one during my first walk with the 50mm.
I had to crouch quite low to get that perspective (remove everything that looked like a city from the background) and have only sky and that tree.
Please give me your thoughts on this.
BR René
PENTAX K-30  Photo
03-19-2013, 07:24 AM   #2
smf
smf's Avatar
I applaud that you crouched to get an interesting image. And I like the detail in one of the steps. However, I wish the foreground wasn't quite so dark. A higher ISO probably would have allowed you to have the tree branches in sharper focus. (That's because you could have then selected an aperture giving greater depth of field.) If wind made the leaves blurry, perhaps a higher ISO could have allowed you to stop action. Or perhaps you wanted the apparent motion.
03-19-2013, 07:44 AM   #3
wullemaha's Avatar
In this case the aperture was chosen on purpose, since it was about testing the possibilities of the 50mm.
I would like to go there again though to try to lighten it up a bit.
Also since it was already close to sunset, so time was running too short to try more versions.
Thanks for the feedback, much appreciated.
03-19-2013, 12:13 PM   #4
PEG Moderator
Kerrowdown's Avatar
Ok, brilliant you found where to post your images.
IMHO, this image is under exposed by about 1.5 of stops, if shot originally in RAW you will be able to pull it back in PP, without any artefacts in the sky becoming apparent.
This now b&w image, could still do with a extra contrast and the shadow information being pulled out, as there is a lot of lost detail in the actual stonework of the steps, which is actually there.
critique, photography
Night Running in the stairs ASa Photo Critique 3 11-23-2012 01:37 PM
Weekly Challenge Winners Project 52 - 4- stairs Symbio Weekly Photo Challenges 8 09-01-2012 10:46 AM
Project 52 Project 52 - 4 - Week 43 - Architecture - Stairs photolady95 Weekly Photo Challenges 12 08-27-2012 08:51 AM
Architecture Vatican Museum Stairs Dionisis_K Photo Critique 15 08-23-2011 09:25 PM
Architecture Stairs (bright light mood) bombel Post Your Photos! 8 03-27-2011 04:05 AM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
