There is a nice sense of depth. Foreground flowers, mid ground tree and mountain in the background. The side lighting helps define the shapes. It's easy to suggest things that may or may not have been possible. If it were possible I would have liked about 10% more foreground and 10% less sky. I'd agree with with baro-nite on the pp. There seems to be a lack of overall sharpness. Looking at the aperture f22, it's likely due to diffraction. If you could have used f11 or f8 I think it would look crisper. Unless the foreground flowers were only a couple of feet away f22 is overkill. If they were say 6ft away you could have used f11 and had a dof from 2' 11" to infinity. There is a chart here
Depth of Field Table that you can insert your camera and lens and it will show you your dof at different apertures.
