Originally posted by atupdate Thanks Paul and carrlangas for taking a look. I want to get this printed for the rescue group the puppies came from (SICSA.org).
Tim
The end result is pretty good, and the effort you have spent is clearly for a worthy cause.
I know it will be well appreciated.
The only way to really tell it is a composite now is that the bottom left dog really should have a closed eye, if there is a paw over it, but that is really nit picking on my part. Maybe though, in looking at it you could shift the top pale pup just a little to the left, with the paw on the ear, not over the eye. I am not sure what that does to the overall symmetry if any that you are trying to achieve with the shape of the mound of puppies, it might make the overall outline look unnatural if you shift the top dog over too much
I have always loved puppy shots, they were a big thing back in the 50's and 60's, usually with the pups all lined up on or over the back of a big sofa.
Edit note. Perhaps also move the right hand pup closer in, to keep the nose to nose spacing on the bottom 3 more consistent, basically lining up the jaw of the right pup to the shoulder of the middle one, and then maybe, just maybe, reduce the size of the top dog just a little, although it might make the perspective look odd. Just some fine thing thoughts. As I said, it is a pretty good composition as is.
