Originally posted by amoringello ...the grass is well exposed and the upper portion is a bit under-exposed to my taste...any CRT is probably getting a bit old and will be darker. My assumption is that matches well with what you're seeing on the TFT where as everything is a bit too dark on the CRT?
Yes you're right, the images appear darker in CRT probably because the CRT is old and its losing quality. Can you tell me why the upper portion is a bit under-exposed and how can I solve this?
Thank you for your availability.
