Originally posted by don88l a location where I can get both the museum and bridge in one shot
I would ignore the pedestrian bridge unless you have a fisheye lens and you want to include the Red River and part of St. Boniface in the frame. As long as the museum fills most of the frame, the bridge tower is just background clutter. I second the suggestion of trying to get light reflections either early or late in the day. There are some buildings to the west that might block the setting sun, so morning might be better. As long as the construction fencing is up, try backing up from the museum and use a longer focal length. Once the fencing is down and there is some green grass (July?) then you can move closer and widen out your shot. If you can get a higher elevation to take your picture, that would also help. I like the way the lines all point to the spire in the centre, that's where the distortion of a wide angle shot is an advantage. It accentuates the design of the building to start with a wide base and flow towards the pinnacle at the top.
