Hello - as per title , can you dear forum members see on your screens and let me know whether the photo below looks too dark for you or not ? I am having problems as on one of my screens it does look very moody but not too dark , and on the other one it does look a bit too dark. For example there is one of doublesided razor blades partially visible at the right edge of the photo - in the middle of height , below the coins (behind small leaf). Is it distinguishable to you or not ? One one of my screens it does appear clearly, on the other it is a bit too dark there - although still visible.
So please share your impressions on the matter as well as about the photo itself.
This is my submission for the K3 contest (
Sharp emotions... ) so I really need your opinion on this - does it look too dark or not ? Should I brighten it up tiny bit or leave it as it is ?
EDIT: Also please check below the photo for other versions as I also struggled with WB setting on my screens.
Thanks in advance !
,,, '>' manntax
Here is the original version :
EDIT:
I tweaked the image and reduced the darkening on the edges and the bottom part - please let me know if that's better to your eye. Thanks in advance !
I have to say though that it is very frustrating to not be able to control in 100% the way the image looks to the viewers - it really spoils the joy of creating in digital imaging..
Here is a version with only vignetting changed :
And here is same as above with tiny bit changed color temperature to match what I intended ( WB is biasing little bit into the warmer, less greenish shade - as the xerox seems that also biases a bit there so I relying on that had it few points off to the green side) :
THIRD version - more WB tweaking to get it right on calibrated screens - I think I need to take a break and come back to look at those all images and pick the right version. Hopefully once I decide which version is ok I will know how to deal with WB from then on - so I really appreciate any help...
Reason: deleted other viersions - the choosen one is in the last post
