Thanks all!
It's great being able to get a 2nd, 3rd, 4th, ..., nth opinion
Originally posted by axelm7 On the lighting and background: if you wanted to convey a stronger sense of that "explosion" I think you could have used the same kind of framing, with stronger flash on one side to create deep shadows on one side, maybe with a strong continuous light behind (but not directly behind) the pod to create some light fringing. Play with strong shadows and contrast if you're unsure of how to approach it more creatively, as your current rendition may seem a bit too evenly lit for the concept you were going for.
The floating effect is perfect for it, though, as the purpose of those seeds is to spread floating through the breeze.
I appreciate the detailed suggestions
, I'm often thinking about how to create more dynamic but still relatively simple backgrounds.
Originally posted by bobD Would need something like your nylon super-glued to the seed (and cloned out later) as you have done to hang the pod.
You could even take a longer exposure and move only the nylon attached to the seed to give the impression of it blowing away...
I had also tried to photograph a single seed and I've found the seed fibers cling to any thread or line I've tried via static electricity, making it impossible to erase the line cleanly in post, not to mention tough to have a natural looking 'floating' seed. This will require more contemplation
or an exercise in patience trying to drop seeds in front of the camera and capture them midflight.
The long exposure's an interesting idea, hmm. A timelapse might also be interesting.
Originally posted by joip A beautiful shot of one of my favorites. I have Asclepias Tuberosa in my garden and right now the pods are starting to open. I take them and plant them in other areas of my garden to increase the monarch habitat. The detail in your shot is just amazing! Love it.
These seeds are all destined to be planted
. I find it easier to put entire plants in with the monarch caterpillars we bring inside (to rear and release), so it's handy to have some smaller ones started by seed in the spring. Any plants that don't get fed directly to them get planted outside
. Asclepias tuberosa's a great garden plant
