Originally posted by DeadJohn That's a good shot considering the 18-55 is a basic kit lens with limited sharpness.
- The building lights south of the Empire State Building (right half of the image) don't have much color to them. I might try an alternate composition with the ESB shifted right, moving the colors on the left more into the frame.
- The sky looks a little blotchy but I think that's because of jpg compression on the forum, not anything you can control. Your original probably looks better.
- Was this cropped to the wide format from a single 18mm image, or did you stitch several 55mm images together? It's not important for on-screen viewing but if you ever want to print very large stitching can give a lot more resolution.
Thanks DeadJohn, for your feedback! I did crop this to a wide format from a single image.. I thought I would have ESB in the center as there was a boat (well lit) further left of the image that was distracting and had to be cropped out..
