Sometimes the light cooperates, sometimes it doesn't.
A tighter, more panoramic crop might work better. The sky really adds nothing to the image. The left foreground could be cropped inside the vertical branch, the bottom could be cropped probably halfway between the outflow and the already chopped next fall. I would start cropping the right edge at about where the furthest outflow disappears behind the rock rise and maybe even work my way in from there.
The other issue is the heavy moisture/haze in the air. A polarizing filter would have helped. You can also try gamma/black point adjustments (one or both) or even just an overlay to try and bring more pop to the scene. Contrast alone is not the problem, I think it's called tonal separation.
aside from the crop, I did a shadows highlight adjustment (25/25/225 + 25/25/225) and black clip of 10%/added a gradient overlay from top/ +15 saturation/adjusted midtones to 1.30 in levels/and a 75% linear contrast curve
